Ga door naar hoofdinhoud
TCA Quadrant Calibration
    • If you have your Quadrant plugged-in, then unplug it.
  1. TCA Quadrant Calibration, Lower all levers: stap 2, afbeelding 1 van 2 TCA Quadrant Calibration, Lower all levers: stap 2, afbeelding 2 van 2
    • Mover each of the 3 levers to the lowest position.
  2. TCA Quadrant Calibration, Press and Hold the Indicated button.: stap 3, afbeelding 1 van 1
    • Press and hold the button highlighted.
  3. TCA Quadrant Calibration, Plug to USB port While holding the button.: stap 4, afbeelding 1 van 1
    • Connect your Quadrant to USB port while still holding the button.
    • Once connected, wait a few seconds and let go of the button
    • You can connect to:
    • USB port of your PC.
    • USB Port at the back of your TCA Yoke.
    • USB port of your Xbox.
    • Do not use USB Hubs or extension cables.
  4. TCA Quadrant Calibration, Move all levers up: stap 5, afbeelding 1 van 2 TCA Quadrant Calibration, Move all levers up: stap 5, afbeelding 2 van 2
    • Pull each levers to the highest position.
    • Move the levers smoothly for better calibration.
  5. TCA Quadrant Calibration, Press the Indicated buttons: stap 6, afbeelding 1 van 1
    • Press these 2 buttons at the same time.
    • This should save the calibration.
Eindstreep
Formica Fusca
2.595 Reputatie
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 344
