Ga door naar hoofdinhoud
T-Mobile SDA (HTC Tornado) SD Card Replacement
  1. T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: stap 1, afbeelding 1 van 3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: stap 1, afbeelding 2 van 3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. T-Mobile SDA (HTC Tornado) SD Card Replacement: stap 2, afbeelding 1 van 2 T-Mobile SDA (HTC Tornado) SD Card Replacement: stap 2, afbeelding 2 van 2
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. T-Mobile SDA (HTC Tornado) SD Card Replacement, SD Card: stap 3, afbeelding 1 van 1
    • Locate the slot for the SD card on the back of the phone. Insert the SD card so that the copper connectors on the card line up with the connectors on the phone (no card pictured).
  4. T-Mobile SDA (HTC Tornado) SD Card Replacement: stap 4, afbeelding 1 van 1
    • Secure the SD card in place by sliding the silver tab over it (SD card not pictured).
Conclusie
Colin Horgan
32 Reputatie
2 handleidingen geschreven
Clemson, Team 15-4, Benson Fall 2012 Lid van Clemson, Team 15-4, Benson Fall 2012
CLEM-BENSON-F12S15G4
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 269
