Wat je nodig hebt
The back of the phone is held on with a combination of plastic clips and adhesive.
The entry point is the speaker grille near the bottom of the phone. Be careful not to insert the opening tool directly downward to avoid damaging the speaker.
Insert a plastic opening tool in the hole in the back of the phone as shown to lift the back cover.
Insert a guitar pick to keep the plastic cover lifted.
Work a guitar pick or opening tool around the edges of the back panel to disengage all clips.
There is adhesive around the edges of the back panel as well as around the camera.
Insert the hook of a Halberd spudger into the small opening above the plastic part covering the fingerprint sensor and pry it off while covering it so it doesn't go flying away.
Disconnect the fingerprint sensor flex cable with the flat end of a Halberd spudger or an opening pick and set the back panel aside.
Remove 10 black Philips screws (including one covered by a white sticker below the camera lens).
Remove 12 silver Philips screws.
Gently peel up the bottom half of the metal tape to reveal...
Two more black Philips screws to remove.
Disconnect the battery flex cable.
The battery is held in by 3 vertical strips of adhesive. Use rubbing alcohol and/or heat to soften the adhesive.
7 andere personen hebben deze handleiding voltooid.
