Ga door naar hoofdinhoud
T-Mobile Huawei Prism U8651T LCD Replacement
Wat je nodig hebt
  1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: stap 1, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: stap 1, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: stap 1, afbeelding 3 van 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: stap 2, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: stap 2, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: stap 2, afbeelding 3 van 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: stap 3, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: stap 3, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    T4 Torx Screwdriver
    $5.99
    Koop
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: stap 4, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: stap 4, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: stap 4, afbeelding 3 van 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: stap 5, afbeelding 1 van 2 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: stap 5, afbeelding 2 van 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: stap 6, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: stap 6, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: stap 6, afbeelding 3 van 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: stap 7, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: stap 7, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: stap 7, afbeelding 3 van 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: stap 8, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: stap 8, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: stap 8, afbeelding 3 van 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: stap 9, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: stap 9, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: stap 9, afbeelding 3 van 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: stap 10, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: stap 10, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: stap 10, afbeelding 3 van 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: stap 11, afbeelding 1 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: stap 11, afbeelding 2 van 3 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: stap 11, afbeelding 3 van 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dillon
578 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 1-7, Lauer Fall 2014 Lid van Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 825
