Ga door naar hoofdinhoud
Sylvania SDVD9004 Motherboard Replacement
Wat je nodig hebt
  1. Sylvania SDVD9004 Motherboard Replacement, Back cover: stap 1, afbeelding 1 van 1
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Motherboard Replacement: stap 2, afbeelding 1 van 2 Sylvania SDVD9004 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Motherboard Replacement, CD Drive: stap 4, afbeelding 1 van 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: stap 4, afbeelding 2 van 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: stap 4, afbeelding 3 van 3
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  5. Sylvania SDVD9004 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  6. Sylvania SDVD9004 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
  7. Sylvania SDVD9004 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Remove Ribbon from Rear Panel
  8. Sylvania SDVD9004 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Anchor screw removal
    • Use Philip's head screwdriver
    • Place head of driver into screw on mother board.
    • Remove all four screws
  9. Sylvania SDVD9004 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Lift motherboard to expose battery
Conclusie
Sarah Henry
417 Reputatie
4 handleidingen geschreven
Baylor, Team 5-10, Williams Fall 2016 Lid van Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
2 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 391
