Inleiding
This guide will show you where to unscrew, how to split the device apart, and then how to disconnect a failing battery from the rest of the interior electronics.
Wat je nodig hebt
Unscrew seven 17.95 mm screws on the side of the device.
Unscrew the 13.87 mm screw.
15 andere personen hebben deze handleiding voltooid.
11 opmerkingen
This seems very easy. Will try amd make an update
This was helpful but my swiffer vacuum had a plastic chassis for the battery and I had to remove the circuit board as well to route the wires on my replacement battery as they were not is the same places as the factory battery.
Where do you purchase the batteries
Where do you purchase the batteries?
One place you can get the battery pack as shown is here; https://sweeperbattery.com/. The latest model (easier to install) battery in a case (6 cell - 7.2 volt) is also available from amazon.
