Ga door naar hoofdinhoud
Swann Doorphone Video Intercom Microphone Replacement
Wat je nodig hebt
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: stap 1, afbeelding 1 van 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: stap 1, afbeelding 2 van 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: stap 1, afbeelding 3 van 3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: stap 2, afbeelding 1 van 2 Swann Doorphone Video Intercom Microphone Replacement: stap 2, afbeelding 2 van 2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: stap 3, afbeelding 1 van 3 Swann Doorphone Video Intercom Microphone Replacement: stap 3, afbeelding 2 van 3 Swann Doorphone Video Intercom Microphone Replacement: stap 3, afbeelding 3 van 3
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: stap 4, afbeelding 1 van 3 Swann Doorphone Video Intercom Microphone Replacement: stap 4, afbeelding 2 van 3 Swann Doorphone Video Intercom Microphone Replacement: stap 4, afbeelding 3 van 3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Conclusie
Emily Stenke
555 Reputatie
4 handleidingen geschreven
USF Tampa, Team S2-G4, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 338
