Ga door naar hoofdinhoud
SwagTron T1 Outer Shell Replacement
Wat je nodig hebt
  1. SwagTron T1 Outer Shell Replacement, Back Panels: stap 1, afbeelding 1 van 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Outer Shell Replacement: stap 2, afbeelding 1 van 3 SwagTron T1 Outer Shell Replacement: stap 2, afbeelding 2 van 3 SwagTron T1 Outer Shell Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Outer Shell Replacement: stap 3, afbeelding 1 van 3 SwagTron T1 Outer Shell Replacement: stap 3, afbeelding 2 van 3 SwagTron T1 Outer Shell Replacement: stap 3, afbeelding 3 van 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Outer Shell Replacement, Outer Shell: stap 4, afbeelding 1 van 2 SwagTron T1 Outer Shell Replacement, Outer Shell: stap 4, afbeelding 2 van 2
    • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
    • These screws will be low into the SwagTron.
  5. SwagTron T1 Outer Shell Replacement: stap 5, afbeelding 1 van 1
    • Turn the SwagTron right side up and slightly lift up the panel.
    • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
  6. SwagTron T1 Outer Shell Replacement: stap 6, afbeelding 1 van 3 SwagTron T1 Outer Shell Replacement: stap 6, afbeelding 2 van 3 SwagTron T1 Outer Shell Replacement: stap 6, afbeelding 3 van 3
    • Turn the SwagTron over and disconnect the wires from the motherboard.
    • Follow the wires to the underside of the SwagTron.
    • Carefully remove the cord and the panel together.
    • All the panels are now free from the SwagTron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Gloria Whang
185 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G5, Banghart Spring 2017 Lid van Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Leden
5 handleidingen geschreven
4 opmerkingen
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - Antwoord
Where can I buy a Swagtron T1 replacement shell?
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig -
Amazon.com Keyword: CertiCable
Jesse Griffis -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,966
