Ga door naar hoofdinhoud
SwagTron T1 Back Panels Replacement
Wat je nodig hebt
  1. SwagTron T1 Back Panels Replacement, Back Panels: stap 1, afbeelding 1 van 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: stap 2, afbeelding 1 van 3 SwagTron T1 Back Panels Replacement: stap 2, afbeelding 2 van 3 SwagTron T1 Back Panels Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: stap 3, afbeelding 1 van 3 SwagTron T1 Back Panels Replacement: stap 3, afbeelding 2 van 3 SwagTron T1 Back Panels Replacement: stap 3, afbeelding 3 van 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Conclusie
Adrian Abarca
363 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G5, Banghart Spring 2017 Lid van Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 687
