Ga door naar hoofdinhoud
Surface Studio Power Supply Unit Replacement
Wat je nodig hebt
  1. Surface Studio Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 1 van 3 Surface Studio Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 2 van 3 Surface Studio Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 3 van 3
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Surface Studio Power Supply Unit Replacement: stap 2, afbeelding 1 van 2 Surface Studio Power Supply Unit Replacement: stap 2, afbeelding 2 van 2
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Surface Studio Power Supply Unit Replacement: stap 3, afbeelding 1 van 1
    • Slowly remove the midframe
    • Be careful: the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. Surface Studio Power Supply Unit Replacement: stap 4, afbeelding 1 van 3 Surface Studio Power Supply Unit Replacement: stap 4, afbeelding 2 van 3 Surface Studio Power Supply Unit Replacement: stap 4, afbeelding 3 van 3
    • A screw retaining the power supply is under the hard drive so both the hard drive and the heat sink assembly must be removed
    • Remove four spring loaded torx screw labeled 1 to 4
    • Remove four torx screw labeled 5 to 7
    • Remove 5mm hex mounting post
    • Use a spudger to remove the heatsink assembly from the motherboard
  5. Surface Studio Power Supply Unit Replacement: stap 5, afbeelding 1 van 2 Surface Studio Power Supply Unit Replacement: stap 5, afbeelding 2 van 2
    • Remove three torx screws holding the hard drive brackets
    • Remove the hard drive and disconnect the SATA/SATA power cable
  6. Surface Studio Power Supply Unit Replacement: stap 6, afbeelding 1 van 2 Surface Studio Power Supply Unit Replacement: stap 6, afbeelding 2 van 2
    • Remove a Phillips screw still retaining the power supply
    • Remove a torx screw retaining the power supply cable
    • Unplug the power supply from the motherboard
    • Lift the power supply up and away from the base unit
Conclusie
5 andere personen hebben deze handleiding voltooid.
The Raptor
6.276 Reputatie
6 handleidingen geschreven
3Gids Commentaar
Does anyone have a source for a new power supply?
AustinMike - Antwoord
Still no source fora power supply huh?
Steve - Antwoord
I recently purchased a MS Surface Studio 6th Generation computer and it seems that the USB ports don’t work properly and the headphone jack is dead…. Any ideas what I need to do to fix it before I send it back?
reowens - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 4,665
