Ga door naar hoofdinhoud
Surface Laptop Studio SSD Replacement
Wat je nodig hebt
  1. Surface Laptop Studio SSD Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: stap 2, afbeelding 1 van 2 Surface Laptop Studio SSD Replacement: stap 2, afbeelding 2 van 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: stap 4, afbeelding 1 van 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: stap 5, afbeelding 1 van 2 Surface Laptop Studio SSD Replacement: stap 5, afbeelding 2 van 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: stap 6, afbeelding 1 van 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: stap 6, afbeelding 2 van 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: stap 7, afbeelding 1 van 1
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: stap 8, afbeelding 1 van 1
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: stap 9, afbeelding 1 van 1
    • Slide the SSD directly out of its socket.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nate Ball
690 Reputatie
5 handleidingen geschreven
4 opmerkingen
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Antwoord
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Antwoord
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 99
Afgelopen 30 dagen: 316
Altijd: 9,579
