Inleiding
Biking is the ideal way of travelling for individuals who may not have their drivers license or don't have easy access to a car. The Supercycle Comp Hardtail Mountain Bike 21-Speed, 27.5-in is a beginner mountain bike that can also be used for regular use. After frequent use of a bike, the tires can develop wear and tear and eventually it must be replaced to use again. So the ability to change either a bike tire, tire tube or tire rim is an important skill to have or learn.
Wat je nodig hebt
Locate and disengage brake to get access to tire; this model has cantilever brakes.
Squeeze the two handles together shown in the first picture and that should allow you to lift up the cable.
The actions of squeezing and lifting should be done at the same time, as the cable is stuck in place if the handles aren't squeezed together.
Follow the same steps with the back wheel if necessary. The bike is now ready to ride again!
