Ga door naar hoofdinhoud
SuperSonic Matrix Mid SC-999 Back Cover Replacement
Wat je nodig hebt
  1. SuperSonic Matrix Mid SC-999 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Back Cover Replacement: stap 3, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Lift the back cover from the body of the device to expose the internal components.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Harris Dagha
866 Reputatie
7 handleidingen geschreven
Dr Shaverz boyz Lid van Dr Shaverz boyz
Community
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 424
