Inleiding
When games have been in storage or used for years on end, they need to get a good dose of TLC. In extreme cases you need to crack them open to get everything. It can be tense opening up a loved game in the fear that you'll destroy it.
Alternatively, you can open up a game no one liked and make it into an innocuous enclosure for something else.
Wat je nodig hebt
On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
The two halves of the case should open easily.
At this point the game board and pins are freely accessible.
Here you can fully clean the pin set and inspect for damage to the circuit board.
Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
To reassemble the cartridge, follow these instructions in reverse order.
22 andere personen hebben deze handleiding voltooid.
