Ga door naar hoofdinhoud
Sunbeam Snow Cone Maker Motor Replacement
Wat je nodig hebt
  1. Sunbeam Snow Cone Maker Motor Replacement, Dasher: stap 1, afbeelding 1 van 1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Motor Replacement: stap 2, afbeelding 1 van 2 Sunbeam Snow Cone Maker Motor Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Motor Replacement: stap 3, afbeelding 1 van 2 Sunbeam Snow Cone Maker Motor Replacement: stap 3, afbeelding 2 van 2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
  4. Sunbeam Snow Cone Maker Motor Replacement, Motor: stap 4, afbeelding 1 van 1
    • After removing the dasher, turn the device so that you can see the “lock” and “unlock” symbols on the back.
    • Twist the casing so that it is in the unlocked position and remove it from the bottom half of the machine.
  5. Sunbeam Snow Cone Maker Motor Replacement: stap 5, afbeelding 1 van 2 Sunbeam Snow Cone Maker Motor Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the five screws and remove the piece labeled in the picture. You should now be able to see the motor.
  6. Sunbeam Snow Cone Maker Motor Replacement: stap 6, afbeelding 1 van 1
    • Lay the device on its side.
    • Remove the 4 gray rubber “feet” by pulling them straight off.
    • Remove the four 5.5 mm Phillips #00 screws that are under them.
    • Remove the bottom plastic cover.
  7. Sunbeam Snow Cone Maker Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 5.5 mm Phillips #00 screws holding a bracket to keep the cord in place.
    • Remove the the bracket so the chord has room to move.
  8. Sunbeam Snow Cone Maker Motor Replacement: stap 8, afbeelding 1 van 3 Sunbeam Snow Cone Maker Motor Replacement: stap 8, afbeelding 2 van 3 Sunbeam Snow Cone Maker Motor Replacement: stap 8, afbeelding 3 van 3
    • Remove the topmost two 5.5 mm Phillips #00 screws that hold the motor in the case.
    • Remove and replace the motor.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kirsty van Dam
119 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 1,084
