Ga door naar hoofdinhoud
Sunbeam Snow Cone Maker Dasher Replacement
Wat je nodig hebt
  1. Sunbeam Snow Cone Maker Dasher Replacement, Dasher: stap 1, afbeelding 1 van 1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Dasher Replacement: stap 2, afbeelding 1 van 2 Sunbeam Snow Cone Maker Dasher Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Dasher Replacement: stap 3, afbeelding 1 van 2 Sunbeam Snow Cone Maker Dasher Replacement: stap 3, afbeelding 2 van 2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
Conclusie
Thomas Falcon
107 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 820
