Ga door naar hoofdinhoud
Inleiding
Use this guide if debris or water has made its way into your device.
Onderdelen
Geen onderdelen opgegeven.
  1. Sun King Solo Solar Lantern Casing Cleaning, Locate and Remove the Screws: stap 1, afbeelding 1 van 1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Casing Cleaning, Separate the Device: stap 2, afbeelding 1 van 1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Casing Cleaning, Cleaning the Casing: stap 3, afbeelding 1 van 1
    • Using a microfiber cleaning cloth, wipe the debris or condensation from the clear plastic of the device.
    • Buildup of condensation in the device could be due to broken or damaged seals. Click here for a seal replacement guide.
Conclusie
Anna
595 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-3, Lauer Fall 2014 Lid van Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Leden
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 254
