Ga door naar hoofdinhoud
Sun King Solo Solar Lantern Battery Replacement
Wat je nodig hebt
  1. Sun King Solo Solar Lantern Battery Replacement, Locate and Remove the Screws: stap 1, afbeelding 1 van 1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Battery Replacement, Separate the Device: stap 2, afbeelding 1 van 1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: stap 3, afbeelding 1 van 2 Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: stap 3, afbeelding 2 van 2
    • Locate the battery.
    • Gently lift the battery from the device.
  4. Sun King Solo Solar Lantern Battery Replacement, Remove the Battery: stap 4, afbeelding 1 van 1
    • Locate the clip attaching the battery pack to the circuit board.
    • Use tweezers to remove the portion of the clip attached to the battery.
    • Do not pull directly on the wires! They can easily be damaged.
  5. Sun King Solo Solar Lantern Battery Replacement, Replace the Battery: stap 5, afbeelding 1 van 1
    • Align the black wire of the new battery towards the center of the device.
    • Press down firmly on the clip to insure that it is properly connected.
    • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
  6. Sun King Solo Solar Lantern Battery Replacement, Reseat the Battery: stap 6, afbeelding 1 van 1
    • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Anna
595 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-3, Lauer Fall 2014 Lid van Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Leden
5 handleidingen geschreven
8 opmerkingen
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - Antwoord
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - Antwoord
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - Antwoord
Howi can get 6.6 v sunking pro battery?please help me.
kapildeo mandal - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 3,794
