Ga door naar hoofdinhoud
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: stap 1, afbeelding 1 van 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: stap 1, afbeelding 2 van 2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: stap 2, afbeelding 1 van 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: stap 2, afbeelding 2 van 2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: stap 3, afbeelding 1 van 1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: stap 4, afbeelding 1 van 1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Nick Taylor
200 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-5, Forte Fall 2015 Lid van Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Leden
3 handleidingen geschreven
2 opmerkingen
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Antwoord
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 56
Altijd: 11,458
