Inleiding
Battery acid damage is a common issue that can occur in electronic devices like K-pop light sticks. Left unaddressed, it can degrade performance and render the light stick inoperable. This guide will identify and repair battery acid damage on a Stray Kids V.1 light stick and how to prevent further damage and ensure device longevity.
Wat je nodig hebt
Unscrew the battery chamber and remove the batteries.
Check the battery holder for any remaining signs of damage or remaining corrosion.
If the battery holder is damaged consider replacing the battery holder by getting a replacement on Amazon or a rechargeable battery.
Rechargeable batteries are less likely to leak and can be reused multiple times.
Regular maintenance and prompt action are essential for preserving the performance and longevity of your Stray Kids V.1 light stick. Following these steps and taking preventative measures can effectively address battery acid damage and ensure the continued enjoyment of your favorite K-pop accessory.
Don’t forget to take out the batteries in your light stick after a concert.
