Ga door naar hoofdinhoud
Starbucks Barista Steam Wand replacement or cleaning
Wat je nodig hebt
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: stap 1, afbeelding 1 van 1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: stap 2, afbeelding 1 van 2 Starbucks Barista Steam Wand replacement or cleaning: stap 2, afbeelding 2 van 2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Conclusie
4 andere personen hebben deze handleiding voltooid.
David
739 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-42, Regan Winter 2011 Lid van Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Leden
5 handleidingen geschreven
Één opmerking
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 15,850
