Inleiding
If your sharpener is making a loud grinding noise or the electric motor is running but the cutter is not rotating, then follow these steps to replace the gears in your Staples 34462 Electric Pencil Sharpener.
Wat je nodig hebt
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Één andere persoon heeft deze handleiding voltooid.
