Inleiding
If your pencils are not properly sharpening, the problem could be a dull or worn cutter. This guide will show you how to replace the cutter component of your Staples 34462 Electric Pencil Sharpener.
Wat je nodig hebt
Orient the top panel so that the sensor bracket is facing you.
Using a Phillips00 screwdriver, remove four 10.42mm screws.
Using a Phillips00 screwdriver, remove two 6.96mm screws.
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
where can I get a replacement cutter?
