Ga door naar hoofdinhoud
Staples 34462 Electric Pencil Sharpener Cover
Wat je nodig hebt
  1. Staples 34462 Electric Pencil Sharpener Cover, Cover: stap 1, afbeelding 1 van 1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Cover: stap 2, afbeelding 1 van 1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Cover: stap 3, afbeelding 1 van 1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Cover: stap 4, afbeelding 1 van 1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Cover: stap 5, afbeelding 1 van 1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Cover: stap 6, afbeelding 1 van 1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Cover: stap 7, afbeelding 1 van 1
    • Carefully pull the cover from the top panel and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jen Hawkins
470 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 860
