Ga door naar hoofdinhoud
Stainless MOEN Kitchen Faucet Handle Replacement
Wat je nodig hebt
  1. Stainless MOEN Kitchen Faucet Handle Replacement, Handle: stap 1, afbeelding 1 van 2 Stainless MOEN Kitchen Faucet Handle Replacement, Handle: stap 1, afbeelding 2 van 2
    • Remove the sink handle, keeping in mind the orientation of the handle where it was removed—you will have to insert it back the same way.
    • If the screw has not fallen out and is still inside the handle, unscrew it with a Phillips screwdriver.
    • If the screw is inside the handle's ridge keep it on the side, along with the rubber stud.
    Vraag FixBot
  2. Stainless MOEN Kitchen Faucet Handle Replacement: stap 2, afbeelding 1 van 2 Stainless MOEN Kitchen Faucet Handle Replacement: stap 2, afbeelding 2 van 2
    • Dry the space inside the handle and the rod holding it in place with a paper towel.
    • This will allow the screw to tighten better and not slip out.
    Vraag FixBot
  3. Stainless MOEN Kitchen Faucet Handle Replacement: stap 3, afbeelding 1 van 3 Stainless MOEN Kitchen Faucet Handle Replacement: stap 3, afbeelding 2 van 3 Stainless MOEN Kitchen Faucet Handle Replacement: stap 3, afbeelding 3 van 3
    • Put the handle back onto the faucet spindle.
    • Insert the screw into the hole inside of the handle, using the hole on the outside of the handle to tighten the screw with a Phillips #0 screwdriver.
    • The images show the knob detached from the faucet interface to show what's happening. However, your faucet handle should be attached to the faucet for these steps.
    • Sometimes, the screws are tighter than usual, in these cases if you try to screw it in, it may damage that ridge's hole. Make sure before putting the handle back onto the faucet's rod, to put the screw in to see whether or not it is a clean fit.
    Vraag FixBot
  4. Stainless MOEN Kitchen Faucet Handle Replacement: stap 4, afbeelding 1 van 2 Stainless MOEN Kitchen Faucet Handle Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips screwdriver to tighten the screw using the handle's outer hole.
    • If your handle was loose and not detached, just take out your old screw with the screwdriver in counter-clockwise rotation, and replace it with a new one, following the steps mentioned.
    Vraag FixBot
  5. Stainless MOEN Kitchen Faucet Handle Replacement: stap 5, afbeelding 1 van 1
    • Put the rubber stud in the outer hole to cover the space and secure the screw in place.
    Vraag FixBot
Conclusie
Anika Shahid
121 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Thank you for sharing this guide on replacing the handle on a Stainless MOEN kitchen faucet. The step-by-step instructions and photographs were very helpful and made the process easy to understand. I was able to successfully replace the handle on my own faucet following your guide, and it's working perfectly now. I appreciate the time and effort you took to create this helpful resource.
Scott Robillard - Antwoord Deel
What about when you anscrewed the screw but the handle is still stuck and wound be pulled off ?
Hanna Faleide - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 170
Altijd: 9,404
