Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unwind the strings by turning the tuning pegs.
Pull the strings out of the tuning peg holes.
Push the strings out through the back plate holes.
Remove the 11 screws holding the pickguard to the body of the guitar.
Lift up the pickup guard gently.
Flip the pickup guard to expose the wiring.
Place a towel underneath the pickup guard to protect your guitar's body.
Take note of where each pickup is wired.
Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
Desolder the pickups from the potentiometers.
Flip the pickup guard back to its original position.
Remove the screws holding the pickups to the pickup guard.
Flip the pickup guard to reveal the wiring.
Remove the pickups from the pickup guard. They should come out very easily.
4 andere personen hebben deze handleiding voltooid.
