Ga door naar hoofdinhoud
Squier Strat Guitar Pickups Replacement
Wat je nodig hebt
  1. Squier Strat Guitar Pickups Replacement, Pickups: stap 1, afbeelding 1 van 3 Squier Strat Guitar Pickups Replacement, Pickups: stap 1, afbeelding 2 van 3 Squier Strat Guitar Pickups Replacement, Pickups: stap 1, afbeelding 3 van 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: stap 2, afbeelding 1 van 2 Squier Strat Guitar Pickups Replacement: stap 2, afbeelding 2 van 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: stap 3, afbeelding 1 van 3 Squier Strat Guitar Pickups Replacement: stap 3, afbeelding 2 van 3 Squier Strat Guitar Pickups Replacement: stap 3, afbeelding 3 van 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: stap 4, afbeelding 1 van 2 Squier Strat Guitar Pickups Replacement: stap 4, afbeelding 2 van 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: stap 5, afbeelding 1 van 2 Squier Strat Guitar Pickups Replacement: stap 5, afbeelding 2 van 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: stap 6, afbeelding 1 van 2 Squier Strat Guitar Pickups Replacement: stap 6, afbeelding 2 van 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: stap 7, afbeelding 1 van 2 Squier Strat Guitar Pickups Replacement: stap 7, afbeelding 2 van 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ion
479 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-5, Green Fall 2015 Lid van Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 70
Altijd: 6,851
