Ga door naar hoofdinhoud
Sprout Channel Cubby Speaker Replacement
Wat je nodig hebt
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: stap 1, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: stap 1, afbeelding 2 van 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: stap 2, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement, Speaker: stap 2, afbeelding 2 van 2
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: stap 3, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jasen biggins
741 Reputatie
5 handleidingen geschreven
USF Tampa, Team 14-101, Meier Fall 2015 Lid van USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Leden
12 handleidingen geschreven
2 opmerkingen
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Antwoord
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 1,029
