Onderdelen
Geen onderdelen nodig.
  1. Flip the phone over so that the screen is facing down.
    • Flip the phone over so that the screen is facing down.
  2. Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Locate the 5 screws around the back casing. Use a three-prong screw bit to remove all 5 screws
    • Locate the 5 screws around the back casing.
    • Use a three-prong screw bit to remove all 5 screws
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  6. Separate the two cases.
    • Separate the two cases.
  7. Use the plastic opening tool to remove the motherboard from the front case.
    • Use the plastic opening tool to remove the motherboard from the front case.
  8. Locate the three screws securing the speaker. Use a Phillips-head screw bit to unscrew the screws
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  9. Remove the speaker.
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Conclusie
Austin Shores
301 Reputatie
3 handleidingen geschreven
Clemson, Team 13-5, Benson Fall 2013 Lid van Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Leden
12 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 86
