Ga door naar hoofdinhoud
Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement
Wat je nodig hebt
  1. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Back of Phone: stap 1, afbeelding 1 van 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: stap 2, afbeelding 1 van 2 Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: stap 2, afbeelding 2 van 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: stap 3, afbeelding 1 van 2 Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: stap 3, afbeelding 2 van 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: stap 5, afbeelding 1 van 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, The Front Case: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Rubber Keys: stap 7, afbeelding 1 van 1
    • The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Katherine Rieck
101 Reputatie
1 Handleiding geschreven
Clemson, Team 13-5, Benson Fall 2013 Lid van Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 139
