Ga door naar hoofdinhoud
Sprint Sanyo RL-4920 Display Replacement
Wat je nodig hebt
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: stap 1, afbeelding 1 van 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: stap 2, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: stap 2, afbeelding 2 van 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: stap 3, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement, Screws: stap 3, afbeelding 2 van 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: stap 5, afbeelding 1 van 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: stap 7, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement, Display: stap 7, afbeelding 2 van 2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: stap 8, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement: stap 8, afbeelding 2 van 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: stap 9, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement: stap 9, afbeelding 2 van 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: stap 10, afbeelding 1 van 2 Sprint Sanyo RL-4920 Display Replacement: stap 10, afbeelding 2 van 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Olmstead
240 Reputatie
2 handleidingen geschreven
Clemson, Team 13-5, Benson Fall 2013 Lid van Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 246
