Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the external antenna, GPS cover, and GPS module.
Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
With the cover removed you now have access to the circuit board.
Using an 8mm socket you can remove the antenna pigtail.
Release the clip indicate to remove the circuit board.
