Inleiding
Sphero R2-D2 Lithium Polymer Battery Replacement
The original battery is a 3.7V 1400mAh battery manufactured by Ascent Batteries.
Model: ABI-H832370
Original battery dimensions:
H 6.35 mm
W 22.22 mm
L 69.85 mm
This battery also has a yellow wire for an NTC thermistor embedded in the battery pack to monitor battery temperature while charging.
Replacement Battery
Amazon: https://www.amazon.com/dp/B0CSC3WYTZ
It's sold as a "3.7V Rechargeable Lipo Battery 1400mAh Replacement for Logitech MX Keys Mini Minimalist Wireless Illuminated Keyboard"
It's a little bit smaller in length than the original battery but it fits fine.
Note: Please leave a comment if you were able to find other suitable replacement batteries.
Wat je nodig hebt
Start by removing the bottom ring. If the droid can still be turned on, open the Sphero app to connect and turn it on to extend its central and side legs, then remove the bottom ring.
Otherwise, you'll have to first remove the side legs. Use a Jimmy to pop up the covers of the arms and remove the 3 screws holding the arms. Slowly remove the arms and then the bottom ring.
Carefully unplug and remove the original battery from the slot. The original battery connector is proprietary and needs to be spliced into the new battery. Cut the connectors from both batteries. Splice the original battery connector with the replacement battery.
Insert the new replacement battery into the slot.
Plug in the battery connector.
To reassemble the droid, follow the instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
