Ga door naar hoofdinhoud
Sphero Ollie Motherboard Replacement
Wat je nodig hebt
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: stap 1, afbeelding 1 van 1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: stap 2, afbeelding 1 van 2 Sphero Ollie Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: stap 4, afbeelding 1 van 2 Sphero Ollie Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: stap 5, afbeelding 1 van 2 Sphero Ollie Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
Conclusie
Krystal Hedrick
364 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Rose Fall 2017 Lid van UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 721
