Ga door naar hoofdinhoud
SoundBot SB571 Speaker Grille
Wat je nodig hebt
  1. SoundBot SB571 Speaker Grille, Speaker Grille: stap 1, afbeelding 1 van 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. SoundBot SB571 Speaker Grille: stap 2, afbeelding 1 van 3 SoundBot SB571 Speaker Grille: stap 2, afbeelding 2 van 3 SoundBot SB571 Speaker Grille: stap 2, afbeelding 3 van 3
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. SoundBot SB571 Speaker Grille: stap 3, afbeelding 1 van 2 SoundBot SB571 Speaker Grille: stap 3, afbeelding 2 van 2
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
Conclusie
Yana
645 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-50, Cagle Spring 2016 Lid van USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Leden
Één opmerking
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 1,612
