Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
this tv had a bad screen ( ghosting and flickering). This tv is well know for this problem. most of the time there are 3 major causes : bad T CON board, loose flat cables or a bad LCD screen) also a bad lvds connector can cause some problems so also check the connector real good as well the cable.
Due to data loss on my computer i lost all the pictures to make this guide.. if you have questions , feel free to contact me.
Wat je nodig hebt
before we take the tv apart we will do a self diagnostic test on the tv. See for more info in the service manual that i add to this guide.
for a self test on the tv , push following buttons on the remote: display button ( see picture for more info on this button ) channel 5 volume down and than power button.
we will open the tv. first we will remove the BUNCHIN audio undercarriage. So you can move the tv separately
remove the 3 screws holding the panel tot the undercarriage.
remove the other 3 screws as shown in picture 2
lift the panel ( tv) up and remove it from the BUNCHIN audio part ( sole, undercarraige...)
now you'll see all the PCB's.
now it's time to check out the LVDS cable or LCD cable and the LVDS connector. wiggle getnly the cable and check te tv.
in red de LVDS connector. attached on that connector the LVDS/LCD cable.
if the screen or picture is not better you can check out the diodes on the T con board. or follow the trouble shoot page in the service manual.
4 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
4 opmerkingen
I have a CM LEDVD combo TV and DVD that will not turn on. It has power 120VAC and did work after using the DVD. Any ideas??
i have a 75inch tv just stoped playing sound
my bedroom tv is working great
the bell tube dings are audible
please help me
