Wat je nodig hebt
Flip the camera upside down, and observe where the battery door and switch are located on the camera.
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using the blunt tweezers, remove the blue ribbon cable.
Peel off the small adhesive tape located on the top right side of the motherboard.
7 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
Incomplete /slightly incorrect guide, missed some connectors on the board as in the photos they were already unplugged so it almost caused me to rip a ribbon cable.
Very nice guide, it helped me repair my A7 locked shutter (which mechanism was blocked by a small piece of metal). On step 19 there was a small ribbon that was missing in your guide, you can see it is already removed on the top left. There were a couple more small details, but overall such fantastic help, thank you!!
Found this after I done the job. Shame I did not search more. How to return count to zero after fitting the new unit? The count shows previous total, I hoped for zero to show. tia.
Step 20 you forgot the 2 more screws on motherboard. I guess you took photos and notes afterwards. Also these are silver screws not black.
There is also a black screw in bottom left of camera not mentioned. As pointed out the bottom of motherboard also has ribbons not specified here.
