Ga door naar hoofdinhoud
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Wat je nodig hebt
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: stap 1, afbeelding 1 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: stap 1, afbeelding 2 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Phillips #0 Screwdriver
    $5.49
    Koop
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 3, afbeelding 1 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 3, afbeelding 2 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 4, afbeelding 1 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 4, afbeelding 2 van 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 4, afbeelding 3 van 3
    Heavy-Duty Spudger
    Koop
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 5, afbeelding 1 van 2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: stap 6, afbeelding 1 van 1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Conclusie
Chao Chen
79 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-35, Amido Fall 2011 Lid van Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 5,616
