Ga door naar hoofdinhoud
Sony Xperia ZL Volume and Power Button Replacement
Wat je nodig hebt
  1. Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: stap 1, afbeelding 1 van 2 Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: stap 1, afbeelding 2 van 2
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two JIS #00 screws from the back of the phone.
    Vraag FixBot
  2. Sony Xperia ZL Volume and Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the six screws from the phone using a JIS #00 screwdriver.
    Vraag FixBot
  3. Sony Xperia ZL Volume and Power Button Replacement: stap 3, afbeelding 1 van 1
    • Use a nylon spudger to disconnect the seven connectors.
    • Never use a metal spudger around the battery. Use plastic or nylon prying tools instead.
    Vraag FixBot
  4. Sony Xperia ZL Volume and Power Button Replacement: stap 4, afbeelding 1 van 1
    • The last connector is located under the back sticker.
    • Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
    Vraag FixBot
  5. Sony Xperia ZL Volume and Power Button Replacement: stap 5, afbeelding 1 van 1
    • Remove the camera assembly using an opening tool or spudger.
    Vraag FixBot
  6. Sony Xperia ZL Volume and Power Button Replacement: stap 6, afbeelding 1 van 1
    • Remove the motherboard with an opening tool or spudger.
    Vraag FixBot
  7. Sony Xperia ZL Volume and Power Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery with a plastic opening tool or spudger.
    • The battery has adhesive tape that connects it to the phone which makes it difficult to pry out.
    • Never use metal prying tools on the battery. Be sure to use a plastic prying tool to avoid puncturing the battery.
    Vraag FixBot
  8. Sony Xperia ZL Volume and Power Button Replacement: stap 8, afbeelding 1 van 1
    • Detach the plastic covering from the top side of the phone by hand.
    Vraag FixBot
  9. Sony Xperia ZL Volume and Power Button Replacement: stap 9, afbeelding 1 van 1
    • Pry off the signal receptor and front camera using an opening tool or spudger.
    • The signal receptor has adhesive tape underneath so proceed with caution when prying.
    Vraag FixBot
  10. Sony Xperia ZL Volume and Power Button Replacement: stap 10, afbeelding 1 van 1
    • Remove the volume and power button with an opening tool or spudger.
    • For replacement, this component comes as a whole. If the volume and power button do not work, they will need to be replaced together.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Liam Kanaley
433 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Lid van UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 46
Altijd: 2,408
