Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Release all the connectors on board and remove the screws there.
Remove two pieces of cover brackets on the audio jack.
Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
Release connectors connecting on the antenna logic board and finally remove it.
Release LCD connector there and loosen the bottom of the whole flex.
Remove the metal bracket covering on the screen flex.
2 opmerkingen
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
