Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
Insert guitar pick into the gap and slide to cut the sticker around the back cover.
Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
Remove the back cover easily. It comes with camera lens and NFC.
And you can place your new back cover, press the adhesive sticker and done the replacement.
12 andere personen hebben deze handleiding voltooid.
2 opmerkingen
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
