Ga door naar hoofdinhoud
Sony Xperia Z3 Compact Rear Camera Replacement
Wat je nodig hebt
  1. Sony Xperia Z3 Compact Rear Camera Replacement, Heat the cover glue: stap 1, afbeelding 1 van 1
    • Heat up along the edges of the cover to soften the glue.
    • Ideal temperature is around 120 - 150 °C for 60 seconds.
    Alternatively, use a heat pack to soften the internal glue/adhesive holding the screen.
    In any case, make sure the glue/adhesive comes off nicely, otherwise you will have to spend a lot of time cleaning off glue residues before putting the new adhesive on.
    axel - Antwoord
  2. Sony Xperia Z3 Compact Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Place a suction cup on the back cover and pull to open a gap.
    • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
  3. Sony Xperia Z3 Compact Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • Finally, remove the back cover.
    • Be careful, the back cover is fragile and can break.
    • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
  4. Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: stap 4, afbeelding 1 van 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: stap 4, afbeelding 2 van 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: stap 4, afbeelding 3 van 3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove midframe.
  5. Sony Xperia Z3 Compact Rear Camera Replacement: stap 5, afbeelding 1 van 3 Sony Xperia Z3 Compact Rear Camera Replacement: stap 5, afbeelding 2 van 3 Sony Xperia Z3 Compact Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the battery flex connector.
    • Remove rear camera bracket.
  6. Sony Xperia Z3 Compact Rear Camera Replacement: stap 6, afbeelding 1 van 3 Sony Xperia Z3 Compact Rear Camera Replacement: stap 6, afbeelding 2 van 3 Sony Xperia Z3 Compact Rear Camera Replacement: stap 6, afbeelding 3 van 3
    • components on the mainboard are fragile, be careful in the next step.
    • disconnect the flat top cable with a spudger
Conclusie
17 andere personen hebben deze handleiding voltooid.
Sophia
43.810 Reputatie
62 handleidingen geschreven
4 opmerkingen
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Atiyeh - Antwoord
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
gary mckie -
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
Giacomo Ciani - Antwoord
You'll need a new adhesive pad.
gary mckie -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 15,827
