Inleiding
Use this guide to remove the rear-facing camera in your Sony Xperia Z3 Compact.
Wat je nodig hebt
Disconnect the NFC antenna.
Unscrew the screws holding the black midframe in place.
Remove midframe.
17 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
You'll need a new adhesive pad.
