Inleiding
Remove the main flex cable from the Sony Xperia Z3 Compact motherboard. This includes the button cable.
Gereedschap
Onderdelen
First, heat up.
And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
Finally, remove the back cover.
5 andere personen hebben deze handleiding voltooid.
6 Opmerkingen
hi dear
my mobile (sony xperia z3 mini ) it problem in screen, i changed screen but still not work always black how can i do to fixed my mobile ???? plz help me
BR
Swren
Sony's TFT LCD IPS Fuse exploded on Logic Board. Just solder it out. Use a Good Solder + Microscope.
Compact Z3: https://youtu.be/B3GHVfFs2hU?t=263
Logic BoardCHF 23.04 | 32GB Original Motherboard Für Sony Xperia Z3 MINI D5803 D5833 100% Entsperrt Mainboard Android OS Logic board Mit Chips ersetzen++https://a.aliexpress.com/_BUGwJ5++
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne F++https://a.aliexpress.com/_B0hkDt++
Normal Big Z3: ++https://youtu.be/ZUm7n0tCZVM?t=45++
5803 = EU + USA
5833 = Australia + Asia
I can not loosen a screw, what can I do?
Hey Fixit, I will repair my Wifi, but I can not find the component parts on the mainboard on the Z3c
Have a description where is the wifi component similar to these video because on the Z3Compact?
is there label imei or meid in it ???
