Ga door naar hoofdinhoud
Inleiding
How to disassemble the phone and replace the Display Assembly (LCD Display & Touchscreen module).
Video overzicht
  1. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: stap 1, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: stap 1, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: stap 1, afbeelding 3 van 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 2, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 2, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 2, afbeelding 3 van 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 3, afbeelding 2 van 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: stap 4, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: stap 4, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: stap 4, afbeelding 3 van 3
  5. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: stap 5, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: stap 5, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: stap 5, afbeelding 3 van 3
    • Remove the Loudspeaker metal bracket.
  6. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 6, afbeelding 1 van 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 6, afbeelding 2 van 2
    • Remove the two Phillips screws that hold Loudspeaker/Vibromotor module.
    • Disconnect the Coaxial Antenna cable.
  7. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 7, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 7, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 7, afbeelding 3 van 3
    • With the sharp end of the plastic tool carefully subtract the module from the phone housing.
    • The Loud Speaker has some adhesive holding it to the chassis so a little heat on the front will help.
  8. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 8, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 8, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the Touchscreen flex cables.
    • Disconnect the LCD Display flex cable.
    • You can embed the Loudspeaker module to the phone housing with masking tape. This will prevent the ribbon from breaking.
  9. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 9, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 9, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 9, afbeelding 3 van 3
    • Use a transparent packaging tape and stick it on top of the glass. This will help you remove the broken glass later.
    • Preheat the Display.
    • Use a cutter to make a room for a plastic tool.
  10. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 10, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 10, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 10, afbeelding 3 van 3
    • Continue separating the display from the frame by using plastic opening tools.
  11. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 11, afbeelding 1 van 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 11, afbeelding 2 van 2
    • Clean the frame from the remains of tape.
    • Now it's time to test the new spare part.
  12. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 12, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 12, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 12, afbeelding 3 van 3
    • Use a high quality adhesive sticker for the model.
    • This will stick the display to the frame harder and it will save the waterproof ability of your phone.
  13. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 13, afbeelding 1 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 13, afbeelding 2 van 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: stap 13, afbeelding 3 van 3
    • Use again adhesive sticker to atach the back / battery cover.
    • All's well that ends well.
Conclusie
61 andere personen hebben deze handleiding voltooid.
ZFix
185.604 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
307 Leden
1.128 handleidingen geschreven
22 Opmerkingen
Worked! I very much recommend watching the video as well as read the manual to get a complete picture. My total time spent was multiple hours, but largely because it's the first time I'm doing a repair that involves so much glue. Gained a few gray hairs there.
Two stumbles:
I missed the line "The load Speaker has some adhesive holding it to the chassis so a little heat on the front will help.", which cost me a lot of time and worry as I was trying to force the speaker assembly out. Eventually got it out, and it's fine. Ribbon cables will be the death of me some day.
I did not keep the little bit of tape on the display ribbon safe and clean and ended up not using it at all. The written manual doesn't show its reuse, the video does.
Also: getting (almost) all of the glue goop off the back was a tragedy.
Minic - Antwoord
so cool, is simple.
danielassro - Antwoord
She lives, very nice guide! :D
Jroen - Antwoord
My Xperia Z2 touch screen is fixed at a phone repaircenter. I dont know what they do but since that day it looks like my touchscreen living his own life. Especially if i type some text with the stock keyboard. Its very frustrating and my question is.....can i do something about it myself?
Sorry for my bad English btw
Anita van Geel - Antwoord
Before gluing the screen to work well sensors and all that, you need to put some black tape on the camera or sensors?
Is it and seen online tutorials or is not necessary
Hector Gonzalez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 66
Altijd: 88,778
