Ga door naar hoofdinhoud
Sony Xperia Z1 Compact Screen Replacement
Wat je nodig hebt
  1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: stap 1, afbeelding 1 van 1
    • Apply heat to the edges.
  2. Sony Xperia Z1 Compact Screen Replacement, Start prying: stap 2, afbeelding 1 van 1
    • When the glue is warm slowly start prying from the top corner.
  3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: stap 3, afbeelding 1 van 1
    • If the glue is cooled down heat more. Don't force it.
  4. Sony Xperia Z1 Compact Screen Replacement, Cable: stap 4, afbeelding 1 van 1
    • Remove the data cable from the phones body.
  5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: stap 5, afbeelding 1 van 1
    • Test if the new screen works properly.
  6. Sony Xperia Z1 Compact Screen Replacement, The tape: stap 6, afbeelding 1 van 1
    • If the screen works, remove the new screen and add the double sided tape
  7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: stap 7, afbeelding 1 van 1
    • Connect the new screen to the phone.
  8. Sony Xperia Z1 Compact Screen Replacement, Apply force: stap 8, afbeelding 1 van 1
    • Now push town not to tight not to softly to the screen.
    • And that's it. You finished the screen replacement.
Conclusie
30 andere personen hebben deze handleiding voltooid.
jaanparker
952 Reputatie
1 Handleiding geschreven
5 opmerkingen
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - Antwoord
Good video! Help me too! Thanks
Clodoaldo Castro - Antwoord
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - Antwoord
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 17,719
