Inleiding
This guide will replace the rear camera in the Sony Xperia Z1 Compact.
Wat je nodig hebt
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
Één andere persoon heeft deze handleiding voltooid.
