Ga door naar hoofdinhoud
Sony Xperia Z1 Soft / Hard Reset
Wat je nodig hebt
Video overzicht
  1. Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: stap 1, afbeelding 1 van 3 Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: stap 1, afbeelding 2 van 3 Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: stap 1, afbeelding 3 van 3
    • SOFT RESET
    • You can force your device to shut down in situations where it stops responding or won't restart normally. No settings or personal data get deleted.
    • Micro SD card cover
    • Micro USB connector cover
    • Micro SIM card cover
    • Open the micro SIM card cover and you will see a small red button. Press it and you will feel three vibrations and device will shuts down.
    Try already but the red small button is not functioning..and totally not open..but if I charge is OK..
    Roda Ledesma Dumayag - Antwoord
    I try already to preS's that red small button but no responce..totally shutdown if I charge mobile is OK..but not open..tnx
  2. Sony Xperia Z1  Soft / Hard Reset: stap 2, afbeelding 1 van 3 Sony Xperia Z1  Soft / Hard Reset: stap 2, afbeelding 2 van 3 Sony Xperia Z1  Soft / Hard Reset: stap 2, afbeelding 3 van 3
    • FACTORY DATA / HARD RESET
    • Go to Settings > Backup & Reset
    • You have option to backup your data (you must have Google account).
    • After Factory data reset the smartphone will restart.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
    I'm dumb and put my phone in water help
    I am so stupid
    Nghtdestroyer Flashman - Antwoord
    I am dumb and put my phone in water help
    I am so. Dumb
Conclusie
69 andere personen hebben deze handleiding voltooid.
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
29 opmerkingen
I will alrrady presss red bottan then he 3time vibration after no responses. Why I want to broken my pattern lock ...pls help
ansarigroups63 - Antwoord
the same as yours
Tioti Aukitino -
forget my paaword
Tioti Aukitino -
i cant get into my menu
roelienesterhuyse48 - Antwoord
http://bfast.ir
اصول صحیح مطالعه
mirmahdi jafari - Antwoord
Normally if you press for 5 sec the ON/OFF button and Volume + button , It will Soft reset
Kendrick XY - Antwoord
it worked :) thaks!
heraa -
It worked for Z1 Compact, thanks
Ariadie Chandra -
Hi, I did as per your quote. My mobile screen got froze and did the ON/OFF button and Volume + . And when I switch it ON normally, it doesn’t turn ON. It just flashes Red LED light 3times. I have changed and inserted with NEW battery, but still it doesn’t turn ON.
Also I won’t loose any of my data, when I did the SOFT RESET.
ram -
Hey I have z1 when I touch settings operate speaking also how can I fix it ?
fanu malik - Antwoord
my touch screen is not functioning how to fix this?
mordz9 - Antwoord
I've done all this several times but still no luck my son's phone has a number pin and we have no code for it and it's not doing a factory reset how can I fix it
michelle wibley - Antwoord
Try what i suggested below :) Hope that helps
Freddie Mckewen -
If you have signed into your google account on your phone, you should be able to sign into Android Device Manager: https://www.google.com/android/deviceman..., here you will be able to do a password removal and/or a factory reset in which everything on the phone is deleted.
Hope everything works now :)
Freddie Mckewen - Antwoord
Whenever I try to start my phone this thing appears that tells me something like"optimizing app"and so on...but it just goes on and on and I can't get to start my phone normally
emmanuela - Antwoord
Please help me
Why is that, everytime i press ' erase everything' the 'Confirmation of PIN' will pop-up, but i dont have pin that register. Help! What to do?!
refulgentel - Antwoord
Also, the problem of my xperia z1 is that, when i open it it just stay good for 15secs. Then it says ' (etc. Not responding) then it gives 2 options, one is WAIT and the other is OK, then if i press ok and wait. The screen will turn black. Then it will restart automatically again and again.
refulgentel: I got exactly the same problem since yesterday, I tried to do the hard reset( with 3 different methods) but that's didnt worked
maxime.debritomontenegro - Antwoord
Fouond any solution ? Same here
kacmar -
I have problem with mobile SONY Z1. I want to Factory data reset. But Its asking for confirmation code..
Kindly help.
tahir - Antwoord
I think the Xperia Z hasn't got a hardware button, can't find it in any port
Joey Ros - Antwoord
Hi, I want to do the factory data reset my phone sony experia z1.
After click erase everything button, it request to confirm password?
but it pop up try again.
which password should i use?
baby_sally87 - Antwoord
Hi I forgot my password .
Now how to open my phone
Jd Dewan - Antwoord
the above procedures doesnt work at all. had to use Sony PC Companion software and select Repair Device to reset/erase the phone.
Chee Koon Teo - Antwoord
Not it will not work, because it will appear type pascode.
Kujtim Morina (Bacakujt) -
my sony z1 automatic shut down,software change,battery change,other than the board the whole changed same problem.
but main camera removing mobile ready
camera fixing,or camera changing same problm
eany solution?
Perfect Sr - Antwoord
When i put my card sim in he begin dowing stufs . Can i fix it pls help me.
Ahmed bouka - Antwoord
i cant on my phone. Its keep on and off.. How to do hard reset
Mohd Fairuz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 244
Altijd: 528,770
