Inleiding
The vibrate motor is located in the lower quarter of your phone. To access it you will need to open up the back of your phone. This guide will help you through the necessary steps required to get your phone vibrating again.
Gereedschap
Onderdelen
Turn hair dryer to medium heat.
Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
Circulate the dryer for a full minute to soften the adhesive binding the phone together.
Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
The grey spacer is located in the bottom right corner of your phone, next to the vibrate motor.
Remove the grey spacer by gently prying it up from the right side with the spudger.
Once the plastic housing has been removed from the main phone body, flip it over to expose the antenna circuit board.
Use the plastic opening tool to remove the antenna circuit board from the plastic housing. This component is held in place with plastic clips and not adhesive.
Simply place the safe open pry tool next to the indicated clip and press on it lightly. The antenna board should pop free.
7 andere personen hebben deze handleiding voltooid.
