Inleiding
This guide will lead you through the steps necessary to replace the motherboard if it is not functioning properly.
Onderdelen
Turn hair dryer to medium heat.
Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
Circulate the dryer for a full minute to soften the adhesive binding the phone together.
With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
Use your fingers to peel back the rest of the adhesive tape away from the battery.
Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
I agree that it would be better to overlay red the two vertical cables. Other than that, this step is rather time consuming, than complicated. Obviously you should be attentive to not damage the cables, but if you put moderate force during 3-4 minutes, the battery will finally separate from the case.
Wondering if itās safe to use hair dryer at this step.
Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
Release the copper tape located at the top middle of the phone with a plastic opening tool. This will take some force since the adhesive is rather strong.
With the plastic opening tool, release the pop connector, by lifting up to release it. The pop connector should still be attached to the copper tape.
Pull up gently on the copper tape and pop connector to remove the back camera. It should pop out easily.
With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
The SIM card of the Xperia Z is located in the unlabeled slot above the power button.
Gently open the cover by pushing it to the left.
Remove the two 3mm Phillips #000 screws located at the middle left and lower right of motherboard.
30 andere personen hebben deze handleiding voltooid.
6 Opmerkingen
Where can you get a motherboard from need on asap
My xperia has wrong negtive postive cnection while charging and now device is not power on and apso not charging can you help me to repair it what is the salution
My phone xperia z had a tiny bit of water that had went into a gab of my mobile it's been over 10 months my phone has signs of positive results of rechargeing with notification led lights, unsure what to do and another my precious memory's, I really would like the screen and phone to function properly asap.
